06-13-2020 05:24 PM - edited 01-05-2022 11:41 AM
Yesterday, I ported NO. out from ITALK BB to PM. Still porting. I used different name when I ported in. Do you know it will be ok for porting? ( the PM user is A, the ITALK BB user is B).
I provided all the correct account information of ITALK BB.
THANK YOU.
Joining Public
06-14-2020 02:59 AM
Thanks @computergeek541, that is good to know 🙂
06-13-2020 07:40 PM
Public Mobile does sometimes send a text message informing the customer of number porting failure including a reason for the failure.
06-13-2020 07:20 PM
No problem! Thank you for choosing my post as the solution 🙂
Hope the new owner of that number enjoys using Public mobile. Also don't forget the $10 referral bonus for the account.
06-13-2020 07:02 PM
THANK U FOR UR HELP
06-13-2020 06:51 PM
If the port fails, they may call the alternate number you provided during signup. Other than that I don't think they send port failure notifications, someone correct me if I'm wrong.
VOIP porting, like landlines can take up to a week. You can keep using the VOIP number until it stops working, that's when you know it is ported. There should also be a "port successful" text on the public mobile sim. If neither of the above occur after a week, contact the mods to have them look into it for you.
06-13-2020 06:47 PM
When you setup the port did you fill in the alternate number? Is yes, Public will call you or they will send you a message. Once the port completes Public will also send you a text.
06-13-2020 06:29 PM
how do I know if the transfer has been rejected? like message etc. because ITALKBB is VOIP company, the waiting period is longer than cellphone company.
06-13-2020 06:12 PM
thanks
06-13-2020 05:53 PM
@cmbchwang As long as you provided the correct information the port will go through the names between Public and your previous provider do not have to be the same.
06-13-2020 05:50 PM
Here’s when and how to contact the Moderator Team:
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work
06-13-2020 05:46 PM
I am ITALK BB authorized account holder, I need to transfer this NO. to somebody. that is why i used the different name
06-13-2020 05:29 PM - edited 06-13-2020 05:32 PM
Only the authorized account holder can transfer a number.
