10-10-2023 02:32 PM
I switched over to public mobile last week and now I can not receive nor send texts to most of my contacts. This includes security codes coming in and my security system communication as well. Has anybody else had a problem with this. I do not know what to do.
Service
10-11-2023 02:07 PM
In the end it turned out my problem was the migration of my number from my previous provider had issues...Support sent a new migration request and I had to put my old sim card into the phone, have the provider accept the migration request, and then switch the sim for Publicmobile... Submit a ticket with an agent at the link provided by hTideGnow is https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
10-10-2023 10:25 PM
I am having the same problem... I cannot send texts but everything else works fine... Tried my Sim on 2 other phones and same problem.
10-10-2023 03:40 PM
I did make sure the SMS was enabled. Thank you so much for the information I will contact the customer service help.
10-10-2023 03:28 PM
HI @MCB77
that is a valid assumption.
I think you should submit ticket with agent and ask them to refresh your account on the system:
10-10-2023 03:26 PM
I tried the SIM in another unlocked phone and it still does not work. I put my daughters SIM in my phone and it works fine. So it must be a SIM issue not a phone issue.
10-10-2023 03:10 PM
@MCB77 Did you make sure SMS is enabled as computergeek suggested? Apparently sometimes there can be a conflict between RCS and SMS and the phone needs to be set to default to SMS when necessary. But if it's not that you can contact a customer service agent for help by leaving a private message here
You'll need to check your community private message inbox for a reply (envelope icon or click on your avatar and select messages)
10-10-2023 02:49 PM
It is an android phone
10-10-2023 02:49 PM
I have been with public phone for 5 days now. I can text my daughter but not my son for example. It is randomly not working with certain contacts. Short code text doesn't work at all.
10-10-2023 02:45 PM
@MCB77 Is it an iPhone using iMessages or an Android phone?
10-10-2023 02:42 PM
Hi @MCB77
so, those you cannot send, they are friends? or shortcode?
those you cannot receive, were they shortcode text? and exactly how many days you have been with Public Mobile?
10-10-2023 02:42 PM
@MCB77 wrote:I switched over to public mobile last week and now I can not receive nor send texts to most of my contacts. This includes security codes coming in and my security system communication as well. Has anybody else had a problem with this. I do not know what to do.
Please ensure that the SMS option is enabled as it is more universally standard accross different devices.
10-10-2023 02:40 PM
You can also try putting a 1 in front of the phone number.
10-10-2023 02:39 PM
I can send and receive texts with some of my contacts but not all of them. Phone calls seem to be working fine.
10-10-2023 02:35 PM
Can you place and receive calls? If problem is only texting try rebooting phone, resetting network settings, reinstall SIM card, clear your cache for your texting app. Also try sim in another unlocked phone.
10-10-2023 02:33 PM
HI @MCB77
you cannot send nor receive? the sending part is important, can you confirm if you can send?
and can you receive phone calls? try and let us know
