Text messages
Debra2
Where do I find questions asked by others in the community?
HI @Debra2   you are in the right place!!
so, are you trying to ask a question regarding text messages?  you can try to do a search or simply post your questions there.  There are always at least 5 members here at all time and they are all eager to help
toxicfire
the main page shows questions all asked and you can go through pages or in the top search bar if theres something your specifically looking for
https://productioncommunity.publicmobile.ca/t5/Public-Mobile-Community/ct-p/Public_Mobile_Community
RossN
@Debra2 hi just up above ask all questions you can type in and ask your question there,you can also ask here and we will try and answer them 😀
