Text messages
BarryW
  • Why can’t I send text messages longer than 5 or 6 lines especially if they contain an icon?
@hTideGnow wrote:
if you want longer messages or with icon/emoticon, you will need to use iMessage or RCS or use apps like Whatsapp
The above could still be sent as MMS.  Separate chat or instant messaging services aren't required.
TheSterlinger
This is because of the SMS limitation if you turn on your data and try to send the message it should work.
HI @BarryW  this is normal, it is a limitation of the technology , not a problem with PM service
The limit for a standard SMS text message is 160 characters. If your SMS message contains a Unicode character, the maximum character length will become 70 characters long.  Icon is not regular character and hence it won't work
