Tethering?
Isabelle11
Hello everyone.  I hope you are having a gorgeous day.
Can I use tethering with public?
Someone else ask this question a few years back and public mobile didn't offer this. I just thought maybe they upgraded there game.obviously it's not working for me..anyone?
47 REPLIES 47
srlawren
@Isabelle11 wrote:
@srlawren
I have a s3
@Isabelle11  are you able to leave the APN Type field blank rather than choosing one of the options you previously mentioned?
Isabelle11
@srlawren
I have a s3
srlawren
@Isabelle11 wrote:
@will13am
When i click on apn type its only giving me 3 option.  Internet+mms or internet or mms .
@Isabelle11  what's your phone's brand and model?
@Isabelle11 wrote:
@will13am
Are you not able to edit that field and manually enter values?
Isabelle11
@will13am
Isabelle11
@will13am
Doesn't give me the option to add.
@Isabelle11 wrote:
@Anonymous
Yes data is working
If data is working but tethering is not, then add dun to the APN type field as suggested in an earlier post.  Some hardware needs this extra bit of information, not sure why.  I need this for a few devices I own.
Isabelle11
@Anonymous
Yes data is working
Isabelle11
@Anonymous
I already set the apn i had problem connecting to WiFi until i changed it.
wickedgx
Yes it should work. Just be careful of who has access and how much data the tethering user uses.
Tethering does work.  Public mobile has zero restriction on it.
Dunkgirl
  @Isabelle11
Try adding ,dun to your apn type
APN type: default,mms,agps,supl,fota,hipri,dun
What kind of phone, what kind of device is connecting? Is it by wifi, bluetooth or cable?
@NDesai wrote:
Tethering works with PM. @Isabelle11 Double check your APN settings and make sure it's correctly set.
Ah the wisdom of the Oracles.
Indeed, is your data otherwise working?
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
NDesai
CalgaryBen
I'm able to "tether" my laptop to my iPhone via USB and use it to access the internet using my phone's PM data plan, or simply create a personal hotspot for my laptop or tablet to connect via WiFi.  Is that what you're referring to?
 @Isabelle11
It's not about Public Mobile. It's about your phone and computer.
I just did a quick test with my BB OS10 and it worked perfectly fine using USB.
Wifi hotspot also works fine.
hairbag1
