05-10-2023 01:26 PM
It’s frustrating that public mobile customer service is down. It said I should contact an admin here somewhere. I don’t know how.
I upgraded to a brand new iPhone 14 pro.
I had crappy reception before but now it’s a million times worse. Either I can’t hear others or they can’t hear me, or i get constant dropped calls and numbers I phone just won’t go through.
Yes I’ve tried restarting, and checking settings.
No i haven’t tried a SIM card replacement yet because no stores in my town sell them anymore. Somehow i have to get public mobile to send me one.
I’m on the 35 dollar 3G plan. Do i have to upgrade to 4g?
07-09-2023 06:34 AM
Tried that. Still terrible voices quality. Dropping calls, can’t hear people.
07-09-2023 06:16 AM
I have the exact same issue and I am on the 4G plan. Terrible voice service, and most times terrible data service. The browser will say “Safari cannot connect to the internet right now, check your connection”. I have at least 2 bars and cell data is on.
Terrible!
05-12-2023 01:01 PM
05-11-2023 02:13 PM
@hTideGnow Thanks. It’s at 53.0 with no option to update
05-11-2023 01:07 PM
VoLTE needs to be enabled for the device by the provider. It's not just a simple matter of a toggle. However, if the toggle is there then likely it has been enabled. But then some other phones have the toggle and on but volte is not enabled by the provider. Chicken and egg kind of thing.
05-11-2023 12:45 PM
@SabrinaGalactic LTE is not VoLTE, VoLTE is voice over LTE, you can enable it:
iPhone: Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
05-11-2023 12:45 PM
To update Carrier settings profile, go to Settings, general, about. Then Scroll down to Carrier. Next to Carrier, if a new update is available, you'll see an option to perform this update. Otherwise, you'll simply be shown the currently installed
VoLTE is voice over LTE , which is way for voice to connect on LTE instead of 3G
05-11-2023 12:39 PM
@hTideGnow
I’ve tried LTE and and 3G. I’m assuming LTE is the same as volte???
i have no idea how to check if it’s been voice?
What’s the latest carrier profile and how do I do that?
05-10-2023 02:04 PM
There have been more voice issues recently with Public mobile. Not sure if it is due to roll out VoLTE. Did you receive a text from Public mobile stating that your service moved to VoLTE?
Here is some more information:
https://www.publicmobile.ca/en/on/get-help/articles/volte
Other troubleshooting advice:
Manually select either 3G network or LTE. See which one works better.
Network reset of phone (this will erase Wifi password settings)
If still having issues, you can private message customer service agent to check your account:
Please private message CSA via the following link:
Check your private inbox for response. It will take a few hours for response.
05-10-2023 02:04 PM
It’s bad in most areas, but if I stand out in the open (like out on the street) it sometimes works a bit better. I’ve been having to literally take calls outside wherever I go lol and even then it’s not assured it’ll work
05-10-2023 01:31 PM
@SabrinaGalactic you got a new phone, but you still have the old phone with you? if you put it back to the old phone, does voice work well?
You mentioned about dropped calls, did you check in different area? Just wonder if it local network issue
if you need to open ticket , please message them here:
05-10-2023 01:31 PM
@SabrinaGalactic you probably don't need a new sim card
you don't have to upgrade to 4G plan, but try to enable VoLTE and check if it has been voice
And make sure you have the latest carrier profile and please make sure it has the latest iOS
