Temp plan until Payday
rodjames
I have a few dollars in my account, but I don't have enough to top up until payday on Friday.
Is there any way to enable some kind of temp plan using the funds I have so that I can get calls and messages?
Thanks
Rod
8 REPLIES 8
@rodjames wrote:
Not interested in changing my plans, I'm grandfathered in on a pretty sweet deal.
Thanks!
You must have at least enough funds in your account balance to cover at least the lowest priced plan and then change to that plan.  If you want to switch plans again after that, you'll only be able to choose from currently available offerings. Sorry, but that's your only option, that or just going without the service for a short time.
@rukawa0929 wrote:
Just curious,, Can you still retain loyalty reward & autopay bonus after you come back from a suspension and renew??
Yes...as long as suspended less than 89 days. At 90 days, you'll lose account and number altogeather.
rukawa0929
kelvarnsen
@will13am wrote:
Thanks!
Let the account go into suspension and renew when you have funds.  It is the only way to keep plans that are no longer available.
Or try to find a way to get enough referrals between now and your renewal date to cover the difference.
Thanks!
rodjames
Thanks!
RossN
@rodjames hi sorry there is none that I am aware off
Triguy
If you have $10 + tax in your account then you could switch your plan but you could lose any unused minutes/texts/data.  You could then switch back to your current plan if it is one of the current plans.
