02-16-2017 02:00 PM - edited 01-05-2022 01:44 AM
02-16-2017 06:07 PM
@ElectricBrain, are you sure it was a VoLTE call? Did you notice the LTE indicator during the call?
02-16-2017 05:43 PM - edited 02-16-2017 05:48 PM
Unless we can get a screenshot of a phone on LTE and in a call it sounds like someone had a stronger signal and thought they were on VoLTE.
I am in Alberta and my iPhone 6S Plus doesn't use LTE for calls yet, and I don't have the voice & data option under settings. Maybe the carrirer update hasn't arrived yet (I have Public Mobile 27.0).
02-16-2017 04:04 PM
@dearmusic, last year when they had announced VoLTE, Telus had said that they were working to implement it on Telus first and at that point, there were no plans to implement it on PM. However, the OP seems to suggest that VoLTE is working on the iphone in BC/Alberta.. implying that PM is getting it as its rolled out.
02-16-2017 04:00 PM
So like, does it affect Public Mobile users? Or is it Telus only?
02-16-2017 03:57 PM
02-16-2017 03:21 PM - edited 02-16-2017 03:38 PM
Can't speak for iPhones but it doesn't work on my Galaxy S6 when I try to enable says VoLTE is not supported by your current software. Contact customer service for more details.
I'd imagine if PM does support VoLTE it would probably need to be a Telus device to get the proper software revision.
02-16-2017 02:58 PM
02-16-2017 02:08 PM
@ElectricBrain - TheOldVR ANGRY - TheOldVR SMASH!
Wait... I've referred to my self in the 3rd person twice, that's worth a celebratory beverage!
All is good now.....
02-16-2017 02:06 PM
LOL my bad. edited for clarity 😉
02-16-2017 02:04 PM
@ElectricBrain Stop playin with my emotions
From the Telus site... Oops! This product or service isn't available in your location.
Only available in Alberta and BC
Almost had another reason to run out for celebratory beverages!!
