11-06-2016 12:28 PM - edited 01-04-2022 06:05 PM
Telus hub working well on PM. I changed the wireless wan profile in settings to "isp.mb.com" , saved changes then under "Connection - Connection Status" selected the new wireless profile I'd set up and press "Apply". Am currently on Telus wireless internet and of course, speeds up/down are the same. I'm currently on the 30 plan with PM but will definitely be switching to the 90 day plan at the end of the term! If anyone else has the B882 wireless modem, this should work for them.
Service
11-06-2016 01:45 PM
@rhombic FYI: I marked Rockdaddy's post as "Solution" so anyone new searching this topic will realize there is a solution. 👍 🍷
11-06-2016 01:24 PM
11-06-2016 01:22 PM
Thanks for letting everyone know.
