Thursday
- last edited
Thursday
DR_PM
Neither my husband or I can place or receive calls, but everything else works. Anyone else?
Thursday
widespread voice call issue. I think data still work.
if you like, download a VoIP app like TextNow and use it to make calls until issue is fully resolved
Thursday
Thursday
Thursday
Thursday
hi @Blujay
yes, network issue
there is a big thread about the voice calls
try Reboot the phone, or you might need to wait PM to fix the issue
Thursday
this has been reported and affects customers in Ontario and points east. Should be fixed soonly.
Thursday
I am unable to receive or make calls in Whitby, Ont. Is there a service outage?
Thursday
you're right...this has been reported and affects customers in Ontario and points east. Should be fixed soonly.
Thursday
hi @Smitti
Thursday - last edited Thursday
There was reports of outages in BC, Alta. and Ont. yesterday.
Please check the outage map for your area:
Thursday
Appears to be no incoming/outgoing telephone calls since about 10:00 am . London ,Ontario
Thursday
hi @GS11
yes
Thursday
Thursday
Network down?
Thursday
thank you!
Thursday
This issue is also effecting New Brunswick
it seems.
Thursday
Thursday
my payment are up to date. i cannot make calls nor text.
Thursday
hi @Ayala18
Thursday
Thursday
@Daytona93 wrote:I try and make a call, and nothing happens. No message or anything. My texts are working still.
You're likely in Ontario or somewhere east of Ont. There's a network upset right now, should be fixed soon...we hope.
Thursday
My plan was renew
i can get phone calm and data is working but can’t pass phone call
Thursday
's suggestion of putting the phone into airplane mode for a minute or so and then turning it off worked for me. Worth giving that a try!
Thursday
@RickCamilleri 's suggestion of putting the phone into airplane mode for a minute or so and then turning it off worked for me. Worth giving that a try!
Thursday
Thursday
@Riprogers_29 wrote:tried to see if there were any issues, first time using this, Thank you
Keep watching the Community for updates. Also, try a call every 30 mins or so. Let us know when your calls are normal again.
Thursday
I am having the same problem. Hopefully it is resolved soon.
Thursday
Yes, same here. My mom, spouse and I are all on PM and none of us can make calls this morning.
Thursday
Thursday
hi @
