12-11-2022
09:02 PM
12-18-2022
11:05 AM
Dunkman
How contact technical support
Service is no work
No call no text no data
Manually selected 'public mobile' network
I reset and try many times
Simon no help
12-11-2022 09:26 PM
try on another phone, or use other sim card on your phone to try
12-11-2022 09:04 PM
HI @Comrade
check if your My Account is showing active or suspended
also, would you be able to check your phone in another area? maybe local network problem?
to open ticket with PM cs agent to report outage or investigation:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-11-2022 09:04 PM
