TTC stop 898882 text not working
wangl626
I am trying to text to 898882 for checking when the next TTC bus will come, but the text not sending out. Could you help to fix it?
20 REPLIES 20
@wangl626 when was the last time you were able to send shortcodes ?
@wangl626 wrote:
i tried his sim card on other ppl's phone. they are able to send the msg the short code like 680680.  so is that means there are sth wrong on my device?
Huawei is banned in the US which means there are access limitations with the google ecosystem.  The stock messaging app on your phone may not be playing nice.
wangl626
@wangl626   Since we can text this shortcode but seems like you cannot text any shortcode at all, we cannot tell if it is an account issue or device
Do you have another device around? can you put your PM sim card there and test?  This will force a sim reprovision and it could resolve the issue without PM's help
wangl626
no i cannot download it......
@wangl626   can try try downlad the Google Message and use it to text and see if it works?
wangl626
still not working 😞
@wangl626
Open the settings
Tap on Apps
Tap on Apps
Choose an App
Tap on Storage
Tap on Clear cache
will13am
898882 works for me.  I am using google messages with chat enabled.
wangl626
yes yes, Huawei
@wangl626   are you on Android?
wangl626
how do I clear cashe?
@wangl626   so, shortcodes do not work for you
did you try reboot the phone as well as clear cache?
wangl626
i tried other short code i.e 680680... not working either
@Yummy   898882 is a valid shortcode for TTC
wangl626
680680 not working either
@wangl626 wrote:
i can send to others. only this 898882 not working 😞
Were you Ever before been able to text to that number?
Did anybody else had success texting that number?
Maybe you need some symbol in front of number as it is not 'legitimate' phone number.
@wangl626
i wonder if you can text other shortcodes
you want to text something random to 680news? 680680
wangl626
@wangl626   text not sending out?
start with a device reboot
if it still fails, try to clear cache and see if it helps
can you text others? like to a real person as well as text other short code?  test them as well
