03-06-2025 11:53 AM
I waited till my new P.M. sim card arrived and started the transfer process. After going through the 6 steps, I just get the notice that SUBSCRIPTION NOT ACTIVATED. It then says to get support. When I try to connect with an agent, nothing happens. How do I get an agent to help with this broken process?
03-06-2025 12:01 PM
@Bilbo123 yes, many issues recently.
You can try the following link to contact Public Mobile agents gor assistance.
If you are not able to sign in and use it, use the next link below.
Agents usually respond to your inbox within 30 minutes to 2 hours.
