09-07-2023 02:41 PM
How come it wont let me switch from the $45 40 gig can plan to the $50 cdn/us plan ? Its not showing up when I try to switch plans .
09-07-2023 02:53 PM
Maybe you already scheduled it. It won't show up as available if you've already scheduled it.
09-07-2023 02:47 PM - edited 09-07-2023 02:50 PM
Hey @Nick0425
As @hTideGnow said, the website has cache issues. Please go to your browser settings under privacy and clear out the cache. Then close browser and re open. Then try again.
EDIT: don't forget, select the new plan to start on the renewal date and not right away so you don't lose what you've already paid for.
09-07-2023 02:43 PM
HI @Nick0425
Maybe cache problem. Login in Incognito/Private/Secret mode with your browser and check. Make sure you select all plans from the tab
09-07-2023 02:43 PM
@Nick0425 wrote:How come it wont let me switch from the $45 40 gig can plan to the $50 cdn/us plan ? Its not showing up when I try to switch plans .
The $50/30-day plan is still avaialble. Did you select the "all" option in the plan change area?
