07-12-2021 06:34 AM - edited 01-06-2022 02:46 AM
How easy is it to switch phones? I am currently using a iPhone 5C and wish to switch to an iPhone 7 which I used on a different service provider. Phones are unlocked so is it as simple as switching the Public SIM from the iPhone 5C to the iPhone 7? Thank you.
Phones
07-12-2021 08:00 AM
@Colin71 wrote:How easy is it to switch phones? I am currently using a iPhone 5C and wish to switch to an iPhone 7 which I used on a different service provider. Phones are unlocked so is it as simple as switching the Public SIM from the iPhone 5C to the iPhone 7? Thank you.
Hello @Colin71 ,
Yes, it is that simple. The SIM card is what is attached to your phone number and Public Mobile account.
Since these 2 phones have the same sized SIM slot simply remove from the old phone and insert it into the new phone.
After inserting into the new phone, do a Reset of your Network Setting on the iphone 7.
07-12-2021 06:49 AM - edited 07-12-2021 11:26 PM
You can just put your SIM card into your new phone. You do not need to tell Public Mobile.
