06-29-2017 08:58 AM - edited 01-05-2022 02:18 AM
06-30-2017 06:41 PM
@Marynabilousova you were in the right place. The second option is actually:
"Transfer a wireless or wireline number from Public Mobile or another provider"
That is the option you need to choose, and you wil be given the port in request form.
06-30-2017 03:08 PM
06-29-2017 09:18 AM
Porting is a simple self serve function. There is no impact to existing plan with a number change. My suggestion is to wait until the dust settles on the current promotion before embarking on any kind of account change. In the event that something goes wrong, the turnaround time for moderator help is several days. Unless this change is time sensitive, waiting a bit is good idea.
06-29-2017 09:18 AM
I have a question on this, will friend referals follow onto the number phone number?
I had an issue when I signed up, my temp PM Number was still my PM Number in the refral system, after my WIND number was successfully ported in. I had some friends who could not use my number to set a referal.
Tech team had to take a couple days to correct this.
06-29-2017 09:14 AM
06-29-2017 09:02 AM
06-29-2017 09:00 AM - edited 06-29-2017 09:02 AM
If i understand this:
You want to port your PC number over into your PM account, and lose the PM number? It is possible. On your plan you will just have your PC number instead of the PM number after the port, and your PC account will close.
If someone could confirm this is the correct information
