2 hours ago
I will be leaving Canada for a while due to work, and I have two questions that I need your assistance with:
If I work in Asian countries, will I still be able to receive text messages on my Canadian mobile number(236-9788666) base on my existing plan?
Is there a plan that allows me to pay only for text messages each month while keeping my mobile number active?
48m ago
@HELENXXCN - you should edit your post, and remove your phone number, since this is a public forum. It could lead to more unwanted spam calls...
2 hours ago
hi @HELENXXCN
1. sorry , PM only has roaming in US
2. sorry, minimum plan is $15 if you have access, or some have a $19 choice. But check your My Account to see what lowest plan available for you
or you can save some money by suspend for 90 days, then reactivate for 30 days, then suspend for 90 days and keep doing that, depends on how long you are going for
2 hours ago
thank you
2 hours ago
thank you.
2 hours ago - last edited 2 hours ago
@HELENXXCN No and no sorry PM only has roaming in the US with add on or CAN/US plan and will not work anywheres else
