Switching from PM to Koodo
Hmouda
Hi All,
A few days ago, my friend, received a msg from Public Mobile that he could switch his account to Koodo 5 GB for $35. actually, I didn't receive this msg. Is there any way to get the same offer or can I take over my friend's offer?
PJC
Go through the Koodo check out process and enter promo code JOINKOODOAUGDATA then enter your PM phone number as the validation code, if it works, you are eligible.
mimmo
Of you are not eligable for the offer then you can not get the migration offer.
Some people have used someone else's number to get the offer, if you go that route not sure what if any issues might arise.
Effort
If your friend has no intention of switching to Koodo, Koodo doesn't seem to have a problem with people using someone elses number for the promotion. You should be able to activate a new line with Koodo and port over your own phone number. Your friend would be unaffected.
Hmouda
Thanks, I'II try
RobertQc
@Hmouda wrote:
Hi All,
You can try to send a message to 5129 or 5130 and say "offer"
