Switching Subscription
bawa
If I switch to a new subscription will I stay on my old reward system, and will I save the same amount because of the rewards after I switch?
HI @bawa   You will be on the old rewards system and getting the same rewards
Make sure you use "Change plan on renewal" to scheduled a plan change
You'll keep your rewards.
@bawa   Yes, changing plan won't affect your reward systems.  You will stay on the same rewards system you have now
