Switching Sim card to new phone
Jameslafrance
I tried just putting the simple card in the new phone and it doesn't work any suggestions?
12 REPLIES 12
@Jameslafrance
OK, just checking.👍
Jameslafrance
No it's an old Motorola it's not locked or anything
@Jameslafrance
Do you know if your phone is locked by another carrier that is not Telus, Koodo or PM?
What is the make and model of your phone?
Jameslafrance
TX I'll submit a ticket
@Jameslafrance
A CS_Agent will able to retrieve the PUK for you. Submit a ticket on SIMon Chatbot on the bottom of page or private message on the envelope icon above.
On iPhone, you can disable the SIM PIN.
Jameslafrance
Idk as I don't have a sim lock
@Jameslafrance
If it is SIM locked then you need to contact a CS_Agent to get the PUK if you don’t remember the personal unlocking key that you set on your phone.
Jameslafrance
Says I need a sim network unlock pin
Jameslafrance
HALIMACS
@Jameslafrance
  1. are YOU new here...
  2. if so, did you go through the activation portal
  3. is service active
  4. did you change the SIM card in the self-serve portal
  5. did you ensure the 'new' phone works and isn't blacklisted
  6. try another SIM in the 'new' phone to see if it works
  7. check account status, is it active
  8. did you label the account Lost\Stolen and perhaps you have to remove that designation
  9. try rebooting device, resetting network connections, toggling airplane on/off
  10. try the new SIM in another device to see if it works
Anywhere close?
@Jameslafrance
Try rebooting your phone by powering the phone off then back on if you didn’t do that when you put the SIM in the new phone.
hycm53
Are you a new customer or a exist customer? Is you PM account activated? Try reboot the phone.
