09-06-2019 05:58 PM - edited 01-05-2022 06:54 AM
Title says it all, Data works, calling out works, but nobody can call me
Switched from rogers about 5 hours ago, any ideas?
Joining Public
09-07-2019 12:04 AM
Try rebooting the device?
It may also report "Telus" instead of "Public Mobile" for a few days (before the technical-side and account-side stuff all gets synced up), and you might get weird service (like faster-than-you-paid-for Data rates) until then.
09-06-2019 06:06 PM
Thanks I will try that
09-06-2019 06:05 PM
@pearfilms wrote:Title says it all, Data works, calling out works, but nobody can call me
If you Provided correct porting information then just give it a bit more time unless you have received a text from Public saying your port has failed. If that is the case get in touch with the @CS_Agent
09-06-2019 06:04 PM
You should still be able to use your old providers sim until the port completes.
09-06-2019 06:02 PM - edited 09-06-2019 06:03 PM
To contact a moderator, you need to create a support ticket. Explain your issue to SIMON, the ? comment bubble in the bottom right.
Use as few words as possible to allow the BOT to understand you better. Answer his questions until you get to here:
Click on "Submit a ticket" and the Moderator team will take over your case and respond to your concern within 48 hours. May take longer, but the promise of the new Ticketing System was that it will reduce these wait times.
About @Moderator_Team
09-06-2019 06:00 PM
Your port has not completed. This is how PM sets you up until your number ports. It is still possible it will finish on its own, but after four hours they say contact a moderator. It may be stuck.
