Switch current sim card to new phone
12-18-2018 03:49 PM - edited 01-05-2022 02:50 AM
Have a quick question,
I currently have a phone with the public mobile sim card. If I bought another phone to replace this one I currently have, is there anything I would have to do to switch the sim card to the new phone, or would it just switch over and begin working like normal?
Phones
12-22-2018 11:07 AM
Hi Gibson,
You may have to set up APN on your new phone after start up new phone with your current sim by follow instruction in the link below, this will enabled your data plan on the new phone. If you don't do this step you still can make call but may not have data on the PM network. This step is very easy, just take couple minutes then you on your way:
Enjoy you new phone!
12-18-2018 04:27 PM
There may also be a need to check/add the proper APN settings. APN settings is covered in this knowledge base article.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Activate/ta-p/251824
12-18-2018 04:10 PM
@Gibson wrote:Have a quick question,
Just because you haven't said if it was a brand new phone or new to you make sure that it is unlocked or has been used on Telus/Koodo network. You can get phones unlocked for free but buying second hand might cause a bit of a hassle tracking it all down on who to contact.
12-18-2018 03:59 PM
@Gibson just switch it over, pls make sure your new phone work with PM.
12-18-2018 03:59 PM
You should be able to pop sim into now phone no issues.
The only issue is if your phone sim slot is smaller or bigger in new phone vs old phone. Most pm sims in past 2 years have been triple punch. So going smaller should not be an issue
12-18-2018 03:58 PM
Just switch it over.
Check willmyphonework.net first though. You need to make sure the phone is compatible.
