LeTV Le Pro 3
12-18-2018 03:58 PM - edited 01-05-2022 02:50 AM
Alright guys, So I own a Letv LeEco Le Pro 3, as seen here:
https://www.youtube.com/watch?v=vfTIx-DWcmo
Its designed & manufactured for the chinese market, anyways it has worked flawlessly with every other canadian carrier I have had, its a great phone for the price.
Anyways
I dont get texts other than the ones from public mobile or my bank account notifications, and i'm tired of not having texting, Please help fix!
i have already setup the sim/APN/ and have sellected the public mobile 3g network and registered on it, data works, calling works, just incoming texting does. not. work.
thanks!
Phones
12-19-2018 12:21 AM
@JoshuaVP wrote:attempted
@Anonymous wrote:
@JoshuaVP wrote:Alright guys, So I own a Letv LeEco Le Pro 3, as seen here:
Anyways
thanks!
I'm confused. You say incoming does not work but you say you get texts from here and your bank.
APN has nothing to do with SMS texting. That's for data or MMS.
There's an SMSC number that needs to be set properly. See if you can find what yours is and I'll have a look for what it's supposed to be.
There it is: 16475800172
to update smsc code, came back update error
Does this work for you?
12-19-2018 12:09 AM
attempted
Anyways
thanks!
12-19-2018 12:03 AM
plz flash my phun.
12-19-2018 12:02 AM
i get texts from like th "676859" numbers
12-18-2018 04:23 PM
@JoshuaVP, try using a different texting app. I have a LeEco Max2 running lineage OS. It works fines.
12-18-2018 04:04 PM - edited 12-18-2018 04:05 PM
Anyways
thanks!
