Support
Ehamblett61
I accidentally locked my sim card. Now it is asking for the PUK #
How do i get that number to unlock the sim card.
@Ehamblett61
Did you try any of the recommendations on your other post?
https://productioncommunity.publicmobile.ca/t5/Get-Support/Support/td-p/960514
Can’t blame PM for something you locked.
Ehamblett61
Tel: xxxxxxxxx
Add: xxxxxxxxx
I accidentally locked my sim card. Having problems getting the PUK # to unlock it. I've be directed to do several password change. I am now too frustrated without my phone service.
Please help.
Edit by Dunkman: removed personal information
@Ehamblett61
If you have an iPhone, go to Setting>SIM PIN>disable SIM PIN.
Otherwise contact a CS_Agent by submitting a ticket on SIMon Chatbot on the bottom of the page or private message them on the envelope icon above.
HALIMACS
@Ehamblett61
Click on "Chatbot (SIMon)" below under the "Get Help" section, tap "Chat with SIMon", then type 'need PUK', follow precise instructions toward submitting a ticket to the customer support agents.
