03-18-2024 02:34 PM
I accidently set up another subscription part ways how can I delete it please help me
My Account
03-18-2024 03:54 PM
Thanks
03-18-2024 03:52 PM
hi @kimmy45 no PM is one email for one account. You need to use another email to create a new account
03-18-2024 03:51 PM
Thanks for the help..... Just another question is it possible to add another phone with another number to an existing subscription?
03-18-2024 02:40 PM
So many interpretations of the original question !!
03-18-2024 02:39 PM
HI @kimmy45
so, it was a new subscription? you want to cancel the subscription? or you want to cancel the port?
if you want to cancel the subscription, support agent can help, but not sure if they can refund the amount, check with them. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-18-2024 02:38 PM
@kimmy45 wrote:I accidently set up another subscription part ways how can I delete it please help me
Do you mean you changed your regular plan to a different plan ? If so, did you select Change Now or Change at Renewal ?
03-18-2024 02:36 PM
Did you get charged? Did you activate SIM?
If not I would not worry about.
