01-14-2024 02:52 PM
How can I get a new account changed to a card not a eSIM. This old phone can't download the app of public mobile so I want the number to be on the sim card. I know i need another SIM card in witch i have, i don't want eSIM because of old phone it won't work. I want my auntie number connected to her card.
01-14-2024 04:42 PM
@Cecil1942 If I'm not interpreting your question correctly, please reply back. So you know, you cannot re-use a SIM. eg. you cannot take your PM SIM and assign it to your Aunt's PM account to have her number on your SIM card. If you mean that you have a new SIM card that's unused, @Handy1 below is correct, you just need to assign the SIM to your Auntie's account and put it into her phone. If you do this you won't need the app to do the activation.
01-14-2024 03:23 PM - edited 01-14-2024 03:24 PM
@Cecil1942
Your account is on your existing SIM card so try putting your SIM into your aunt’s phone and see if it works or vise versa.
01-14-2024 02:54 PM
@Cecil1942 You can SIM swap the number in your account profile page
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
if you cannot log in you can get support to do it for you
send a private message To CS_Agents
