Subscription not activated
TheKaburagi
I just got the 90 day plan for 90gb, but trying to activate the plan and the app simply says subscription not activated after I went through all the steps, and just told me to contact customer support. Please advise, thanks. @CS_Agent
Edit: ok i missed the envelope that allows me to private msg the CS agent, that for some reason doesn't show up on mobile. Thanks.
DaveLi
I have the same issue today as I tried to activate through the app.
You tagged CS_Agent @TheKaburagi , but none of us here are CS_Agents.
If you click on that CS_Agent link you posted you will see another window open up. Look to the right where is says 'SEND A MESSAGE'. If you click on this you can private message Public Mobile representatives.
@TheKaburagi
Are you porting your old number over to PM? If so, did you use your previous carrier account number or IMEI?
If you picked a new number, private message a CS_Agent on the envelope icon to get further assistance with activating your SIM.
@TheKaburagi  First check credit card make sure you weren’t charged if not try again in an hour , if you were charged put SIM card in phone and reboot it
TheKaburagi
Here is a screenshot of the problem.
