Subscription errors
AllanAbbott
The plan for my phone number has been incorrectly set to my spouse's account by Public Mobile.  This change to my subscription was not initiated by me, nor was I made aware.  My subscription needs to be corrected.    I need data NOW.   How do I do that?  How do I root cause the problem with Public Mobile and get a resolution?  ...very troubling
2 REPLIES 2
DDM69
Each number/account requires you use a separate email address.  Could that be the issue?  Public is self serve so the mistake was likely made by the customer (Public doesn't manage or make changes to your account).  It may be a cache issue with the browser you were using.
You may need to contact a CS agent to get this fixed.
@AllanAbbott  Use this direct link to support
send a  private message   To CS_Agents click
