Subscription error
KittyGirl
My subscription won’t activate. I paid and I registered my sim, picked my number but it says subscription error and it’s locked to that screen on the app.
2 REPLIES 2
@KittyGirl
Try uninstalling and reinstall the app and try again.
If that didn’t work then contact a CS_Agent through the Chat icon and type in Submit a Ticket for an agent to help.
HI @KittyGirl
are you activating physical or esim?
if physical sim, test the sim in a phone first
if you still need support help,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with My Account login and unable to submit Chatbot ticket,  you can  submit by direct message:
