Subscription Plan
Jcroteau1
Hello,
Been a Public Mobile customer for a couple years and an am interested in ungrading my plan. I'm looking at the 4G 44/Month plan and noticed if I sign up for a 90 day plan it goes down to $39/month. I'm wondering if I keep that plan going indefinitely if it stays $39, or if that's only for the first 90 days.
@computergeek541
Great catch thanks
@BKNS27 wrote:
@Jcroteau1
Once you sign up for the plan the rate will remain as long as you stay with this plan.
Remember that you will be charge $117 plus taxes once you switch but remember to switch on your next renewal date since you have been charge already for your current plan.
You can use 30gb of data over the 90 days slot.
This plan includes 90GB of data.
@Jcroteau1
You can use 90gb of data over the 90 days slot.
hairbag1
@Jcroteau1
it'll continue until you change it....BUT..PM reserves the right to increase plan costs (with notice) as they did in the past with the old $10 plan.
@Jcroteau1  It’s stays $39 for as long as you do t change the plan , you will get 90GB of data on day one for 90 days to use and at the end of 90 days you will have 3 x the rewards to use towards the next renewal
HI @Jcroteau1
it is an ongoing pricing.  $39/month
remember PM will charge you $39x3 in the beginning and give you 30Gb x 3 as well, for you to use it in 90 days
So, once you joined, the price stays
