06-06-2023 12:32 PM
Hello,
I noticed that 5G plans have a clause for unlimited data at reduced speed once the full-speed data has been used up. Does that also apply to 4G plans? Also, do these 4G and 5G plans support multiple SIM cards?
06-13-2023 04:09 PM
Thank you. I meant to mark this reply as the accepted solution.
06-06-2023 02:12 PM
@Typhon You only get reduced speeds after data bucket used on 5G plans
06-06-2023 02:10 PM
@softech wrote:Sorry, only the 5G plans have that features 😞
Please note that the unlimited data after you regular plan data will be reduced to 512Mbps
If it's unlimited data why do you suggest it would be reduced after regular plan data ? Does this mean that even on a 4G plan after all plan data is used up you would still have data at reduced speeds?
06-06-2023 01:12 PM
@8MN4Nt7gqSnTraL Only 5G plans are unlimited. Maybe PM might change them in the future!
06-06-2023 12:40 PM
@esjliv Yes , at least it’s my understanding but things change on the daily around here sometimes too 🙂
06-06-2023 12:36 PM
06-06-2023 12:34 PM
@8MN4Nt7gqSnTraL The unlimited data is only for the 5G plans and you can only have one SIM card per account and email address
06-06-2023 12:33 PM - edited 06-06-2023 12:38 PM
@8MN4Nt7gqSnTraL - I don't believe that clause is accurate, or at least not yet in effect.
edit, oh this is in effect for 5G plans @softech @Handy1 ? Then I stand corrected, apologies.
