Subscriptio from 3G to 4G change
George_S
Hello, with subscription change from 3G to 4G, do I need to change a SIM card? Thanks
Hi @George_S 4G is the same as LTE, just different terms for the same technology.  Different brands use different one
@George_S   You want to go with LTE (which gives you 4G speed).
George_S
After switching to 4G, I only have two network options - LTE and 3G. I still do not have a 4G option.
@George_S no, no need to change anything
the same sim card can be used for all plans offered
