Call waiting
hvac
Hello, I lost my call waiting. Can you help
hvac
Problem was with their end. They did s reboot snd now my call waiting is working
@hvac
maybe a device settings.
are you on iPhone or Android?
iPhone : Press Settings. Press Phone. Press Call Waiting. Press the indicator next to "Call Waiting" to turn the function on or off.
Android:   Phone app,  Tap the More options icon (three dots), Settings,  Scroll down to Supplementary Services, then Tap Call waiting to enable.
Cheetah24
@hvac : Can you explain a bit more about what you mean by lost your call waiting. Is it that you cannot put calls on hold anymore?
