02-13-2025 06:05 PM
my husband subscribed each of our phones yesterday the 12 Feb. but my phone does not call out. My husband Derek’s phone still says it is under our old company, Roger’s.
02-13-2025 06:09 PM
HI @Chris126
for both your phones, make sure the old sim card (Rogers) is removed. Or the Rogers sim is esim, disable it (don't delete yet)
then reboot the phone , go back to the Sim card manager or Settings->Cellular to confirm only Public Mobile sim is there, and Reset Networks Settings and test
If that does not work , and if you have physical sim card, try the sim on another phone
if still unable to connect to PM network or unable to call, ask PM support agent to check, you can submit ticket by direct message:
