54m ago
How do I submit a ticket for my cell not working in Mexico but I have a plan?
40m ago - last edited 39m ago
@Kyle25 for service in Mexico, make sure you turn on Roaming Data on your phone
If you still cannot connect, change the network mode to Manual and try manually connect to each of these networks, one of them should work: AT&T, Telcel, Movistar
If still unable to get it working, ask PM CS agent to check
Private message CS Agent at:
42m ago
Make sure Roaming is enabled and manually connect to AT&T on your cellular settings.
You can contact a CS_Agent if it doesn’t work for help.
