12-02-2024
11:57 AM
12-02-2024
01:52 PM
computergeek541
Something went wrong during my transfer and I now have no service with my FIDO account or Public Mobile. I can't receive my confirmation code via text.
12-02-2024 11:59 AM
HI @Tanuja
if Fido has no service now, the port is likely done
try reboot your phone with the PM sim card there (make sure Fido sim is removed or Fido esim is disabled)
test if you can make calls and if data works
finally, test inbound calls
if outbound call or data does not work, then it is a problem with sim or account setup, message support for help
submit ticket by direct message:
12-02-2024 11:58 AM
@Tanuja I will send you a number to contact for porting. Keep a look in you inbox (top right corner should be an icon of an envelop)
