03-13-2024 03:23 PM
My sisters phone got stolen this morning, I pay the bill but I can’t access the account to stop service. My credit card info is on there. How can I cancel it. She can’t because obviously no phone, help! Thanks
03-17-2024 01:14 PM - edited 03-17-2024 01:17 PM
Once a new SIM (or e-SIM) is purchased, simply log into the EXISTING account (not the new one) go under Profile tab, enter the new SIM card number, insert or load e-SIM onto phone, then it's associated with the same account and phone number.
EDIT: of course, you didn't need to create a new account, you'll need to cancel that one and not proceed with it ... sorry, wish you'd asked beforehand
03-17-2024 01:14 PM
@Unffire1 You can’t and she dosent need a new account just a new SIM card . And sim swap the number in account profile page
SIM SWAPPING profile tabs
She can also choose eSIM if phone compatible
but I would ask support if they can refund you for the new account as you were not aware that you just need new SIM card . And get her original account up and running again . They to can sim swap the number for you if you can’t log into her original account
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
03-17-2024 01:09 PM
Created a new account on a new phone for my sister whose last phone was stolen. She wants to keep the same number she had with public and move it to her new account on her new phone. How can I transfer this, it’s still actually her number . Thanks
03-14-2024 05:07 PM
@Unffire1 wrote:So my sisters phone was stolen, account cancelled etc, very appreciative of the fast work.
Have acquired a new phone and ordered a SIM card, should be here Sunday. I am going to set the phone up in my name, credit card etc and send her the phone in the mail. Is there anyway to keep her old phone number?
Thanks
The key is to avoid mistakenly opening a new account. The instuctions to change the existing account to the new SIM card has been provided. There isn't any reason to need to enter new name and credit card information.
03-14-2024 03:53 PM
Hi,
Yes just have go in My Account to change the phone number.
once in profile there is another section that shows current phone number. Click on the pencil and change it then save.
If fir some reason you cannot access the account use the chatbot to submit the request.
03-14-2024 03:40 PM
Thanks
03-13-2024 03:33 PM
hi @Unffire1
simplest way is to have agent to help to suspend the account
03-13-2024 03:32 PM
If you have not done so, you might want to first supsend your service first until you got a replacement sim card:
Login to My Account, go to Profile page, click Report Lost/Stolen Phone and click Put my service on hold
(or use this direct link: https://myaccount.publicmobile.ca/en/account/profile/lost-or-stolen-phone)
If you are unable to login as you don't have a phone to receive the 2FA code: On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
Ans use the FindMy service to locate the phone and try a remote wipe
Apple: https://www.apple.com/ca/icloud/find-my/
(how to use: https://www.pcmag.com/how-to/find-a-lost-iphone)
Google: https://myaccount.google.com/find-your-phone
Samsung: https://findmymobile.samsung.com/
(how to use: https://www.pcmag.com/how-to/how-to-find-a-lost-android-phone)
03-13-2024 03:28 PM
@Unffire1 Contact support to help
