05-31-2026 11:29 PM
I followed the steps to activate my esim, received the text from my old carrier asking me if I authorize the transfer of my account to Public. I said yes, so they cancelled my account with my old carrier, but the Public mobile gave me a message "Subscription not activated - something didn't go right" so now I have NO phone at all! I can't seem to get through to a support agent either. What do I do??
06-01-2026 12:30 AM
It worked thank you.
05-31-2026 11:33 PM - edited 05-31-2026 11:35 PM
Reboot your phone and try login PM app again and see if it can completed
Even if you are getting the same error, check if the SIM was already installed. Sometimes the error is because the sim was there but not properly setup.
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually. If you cannot find it in Inbox of your email, check also the Spam box.
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM by private message CS Agent using this link:
**Monitor the Community inbox (envelope icon on top right) after ticket submitted, CS Agent will reply there
