Speed and Connection
Guimer46
Connection is super slow. Is something wrong with the network?
Timer
@Guimer46
reset your network
and check APN Settings
and rebooting device.
@Guimer46
Telus could be working around your area and could be a temporary issue.
Check the outage map:
https://istheservicedowncanada.com/status/telus/map
@Guimer46
Where are you located?  City and province?
Try to reboot your phone once
Try changing your Preferred network type to 3G Only and see if it works
Try to test the speed again in another places, maybe just a network/antenna issue at where you are at
If you have another phone, try to put your PM sim card in another phone and test it out again
