Sorry talk is not included in you’re current plan
chmkashmir
Hi all
on April 12 my plan switched to the new 25$ deal which has unlimited talk text and the 1 gb data
it was working fine however today when I try to call I get that message and can’t call out
so frustrating
my daughters plan was also changed to that deal and no problems
when I go to my account and check my plan it looks good says unlimited talk and text
so what do I need to have my account reset? Why would it do this all of a sudden?
should I contact moderator and how would I do that?😁thanks for any help
chmkashmir
Thanks everyone it’s working now!
as soon as someone called me it seemed to fix it
Bailey12
Have you tried calling different numbers or just one number? It might be an issue with just the one number. Hope you get it working.
shskr
In your contacts make sure you add a "1" before area code to all your contacts. This may help, it helped with my contacts.
chmkashmir
Thanks for responding
so this is what happened
i couldn’t make any call just got that message then I had my mom call me and it worked then I tried to call her and it went thru
so hopefully it’s ok now I will try a bunch more numbers
emad
You'll need to reach out for assistance from moderator_team.  Click here to message them
mimmo
Is it one number or all Numbers? Can you receive calls?
That error message can be caused by dialing a number incorrectly.
