Unlimited data at reduced speed?
Newhoneybuns
Hello Everyone!
I would like to know if my current plan says that after I have used the 60GB included in my plan that I will actually get unlimited data at reduced speed or not?
My current plan is the one at the bottom 60Gb for 34$/mo
Edit by Dunkman: removed personal information
Newhoneybuns
@Dunkman I am not sure if I went over with my data or not but when I created this post I had used probably 90% or more since my home WiFi was off from about September 2 or something like that and I was using my data so that my daughter would connect to me and both our TVs were also connected to me... My appointment with the technician was only around September 20 or so... I stopped looking on PM website and app not long after I created this post cause I was making myself sick with the anxiety lol Anyway just wanted to come back and say that if I did go over my data it was good enough for me and my daughter to do our daily little things!!
Thank You again for your help it was very much appreciated!!!
Sincerely Yours,
Newhoneybuns
Newhoneybuns
Thank You very much for the response it's indeed what I thought it would be. I'm close to reaching the 60Gb and I will come back and let everyone know how the experience was on unlimited data at reduced speed... In my opinion it will be better than nothing at all but we'll see 💯👍🏻❤️
And @Dunkman thank you very much for editing the private information I totally forgot to remove that from the screenshot... Thank You a million times for everything!!
Dunkman
@Newhoneybuns
According to your screenshot, you should get unlimited throttled data after using up the 60 GB.  Some customers find the throttled data unusable, while others are fine with the slow data speeds.
BTW, please remove your photo and delete from your album.  It contact sensitive account information like your account number, etc.
