11-20-2024 10:59 PM
11-21-2024 12:22 AM
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
11-20-2024 11:17 PM
There no number to call. Everything is done through tickets. Use the orange text bubble on the bottom right and type in customer service agent. Should let you open a ticket. It's like a email. Send them all your info and tell them what you problem is.
11-20-2024 11:13 PM
Whats their phone number ?
11-20-2024 11:11 PM
Are you new to pm? Are calls and data working? Maybe try resetting network settings.
