a month ago
Like the title says, did the port, number can call out and in and data works but sms and i message dont!
a month ago
Likely an issues with iMessage setup.
In your iMessage settings, see if your phone number is linked to iMessage in the "Send & Receive" section. If not, turn off Messages and then turn back on. Make the the "Send as SMS" is turn on also.
You could try a network reset of phone (note: this will erase any saved Wifi password settings).
a month ago
hi @Dsamac
that is only an iMessage problem
Go to iMessage settings, remove the phone number and reboot phone.
When phone is up again, go back to iMessage and put in the phone number again to re-register. Please look it could take long to re-register, just be patient
