Sms dead
Call91178
Hi after new activation sms dosent work.  Call and lte working
2 REPLIES 2
@Call91178
can you confirm if you activate with new number or port in number from another old provider?
For your SMS issue, PM is having problem provisioning text capability for new activations.  And if you are an iPhone user,  iMessage activation by phone number will also be impacted without a working SMS.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Under-Investigation-Ongoing-Issue-Text-Me...
PM is working on a fix but for now, they can only resolve the issue on a case by case basis.  Please open ticket with PM support by messaging CS Agent here:
Neil11
This is an ongoing issue for new ppl. PM is working on it. You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
