05-04-2026 10:57 AM
My issue still is not resolved. I have dead air when calling out on my Motorola Razr 2025 phone. I have tried two eSIMS with no luck. What could be the issue?
05-05-2026 09:31 AM
Nova Scotia
05-05-2026 09:29 AM
Thank you for the information!
05-04-2026 11:00 AM
are you currently in Manitoba ?
05-04-2026 10:58 AM
did you try Reboot phone and Reset network settings?
you can ask PM to reprovsion the account.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
05-04-2026 10:58 AM
ask PM agent to check
hen submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
