Smartwatch
Jazcat
I bought a smart watch with SIM card slot for Android phones so I'm not sure if I'm to order new SIM cards and how would you sync it to the plan and number you already have.
RobertQc
Please see this guide for assistance so you do not need a second sim / data plan
https://www.wikihow.com/Pair-a-Smartwatch-with-an-Android
wmleung
Usually these "wearable" devices use Bluetooth to pair to your phone and has profile for phone calls, media (a2dp) profiles, etc.  You don't need a separate SIM for that.  However, if you want to have a different phone number for the watch, then a second SIM card is needed.
Hope this helps and good luck.
ShawnC13
PM does not have it where you can have 2 SIMs synced to the same number.
