09-04-2022 11:05 AM - last edited on 09-04-2022 12:01 PM by computergeek541
09-04-2022 05:59 PM
You can always inquire if a travel esim will work in your smartwatch.
https://getnomad.zendesk.com/hc/en-us/articles/360056436294-What-devices-work-with-Nomad-
09-04-2022 03:26 PM
I have the exact same watch works fine with bluetooth and does job, but as mentioned above not an option to get PM data for it.
09-04-2022 01:49 PM
No I guess it works on Lte if I try to connect it says to get a hold of Telus I figured since pm is Telus it would work what a major disappointment
09-04-2022 01:40 PM
NO. PM DOES NOT SUPPORT THOSE SMART WATCHES, PERIOD.
09-04-2022 11:24 AM - edited 09-04-2022 11:34 AM
@Brew12601 there is no eSIM support in PM
You can certainly pair it up in Bluetooth mode, with your phone and have it work via the phone. But the phone itself won't work with LTE data alone as the lack of eSIM support in PM
09-04-2022 11:22 AM
Does this watch takes SIM?
