Slow data
04-14-2022 10:24 PM
04-14-2022 11:24 PM
@JL9 wrote:Yes sole day this will allow it to go from 3 to 10 and work much faster
The HSPA network isn't limited to 10Mbps. In places that are DC-HSPSA enabled, it can go much faster than 10Mbps with a maximum theoretical speed of about 42Mbps.
04-14-2022 10:50 PM
04-14-2022 10:48 PM
If your device is set to LTE under network settings, try forcing it to 3g ONLY, if your device allows you to select this option.
04-14-2022 10:33 PM - edited 04-14-2022 10:35 PM
@chris3400 , the mobile data speed for this service is heavily throttled. You should look at streaming a lower bit rate/resolution video.
04-14-2022 10:33 PM - edited 04-14-2022 10:34 PM
@chris3400 - it could be possible network issues that are hopefully temporary.
But, you could always try these things that could improve your connection/service:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
edit: do you have another phone you can try your SIM card into for a few days to see if the issue is the same? This could rule out a device issue.
