11-24-2023 02:32 PM - last edited on 11-25-2023 01:55 AM by computergeek541
I'm trying to log into my public mobile account and get stuck when it requests me to enter the security code that it sends as a text message to my cell phone. The problem is since joining public mobile yesterday I can't receive calls or texts to my phone. I need support to resolve the issue as its preventing me from logging in to numerous accounts because of this same security requirement.
11-25-2023 12:44 AM
@Gwanzi wrote:
Check Activation Status: Ensure that your Public Mobile service is fully activated. Sometimes there can be delays in activation, especially if you've ported your number from another carrier.
Porting would not cause any delay in activation. Once account is activated, even when a port was requested, the account will be active and the user will be able to make outgoing calls, just that incoming calls would not properly routed to the PM sim until the porting is completed
11-24-2023 03:11 PM
Restart Your Phone: If you haven't already, restart your phone. This can help reset the network connection and may resolve the issue.
Network Settings: Verify your network settings. Make sure your device is set to automatically select a network, or manually select Public Mobile if necessary.
11-24-2023 02:35 PM
HI @Tom_7
if you have not receive any inbound calls at all, it is a incomplete porting issue. , PM porting team will be able to help you with that. I will send you the number to your Community inbox. Call them and they can re-initiate
