Simcard
MattEric
It's too wide either way
2 REPLIES 2
@MattEric  It’s a 3 hole punch  to fit all sizes
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
@MattEric
Public Mobile's sim cards are 3-in-1 like this
See if you can remove the outer frames and make it the size you need
I don't believe so, but just in case it really cannot fit, you will need to buy a new one  from
Once you got the sim card, go to My Account from ONLY a desktop or laptop computer to request Change Sim card (please note that due to some glitches, accessing change sim care from mobile phone or tablet won't work)
